Ok so i had a full rebuild (4T60-e), bushings, raybestos Stage 1 clutches, steels, transgo shift kit Jr., red stripe vac modulator, 4th clutch hub, solenoids... basically all the guts are new.. and a ~3000 stall converter... B&M SuperCooler..
Here is whats up, 1st and 2nd gear are fine but in 3rd gear drives normal untill i get ~4000 rpms then slips at partial throttle or full throttle.. the shop pulled the trans found a spun bushing (not sure what one) and burnt up 3rd clutches and a sticky modulator. replaced the modulator, clutches and bushing and reinstalled.. now same problem, literally took it home and next day drove it and slips.. Any thoughts? i don't want to keep burning up the trans obviously its not good for the shop to have to keep pulling the trans and me with my car in the shop all the time..
I have a check valve in line with the new modulator valve, so when boost comes in it blocks the boost.. they don't have the other side hooked to a vac ball like the TGPs, once side attaches to modulator and other port blocked (just blocks boost) i wouldnt think that would cause a problem would it? My stock vac mod i just boosted into it for YEARS w/o a problem
Plugged -->
<-- Vac source
.......................^^To Modulator^^
Stock trans lasted 147,000 miles so i know its not a problem of to much power.. (~60K boosted) and daily beat
Anyone have any thoughts on why 3rd gear keeps slipn?
Plugged -->
<-- Vac source.......................^^To Modulator^^
