I just finish installing a 3.4L (converted to carburator) on my MGB 1979. I am using a Camaro t-5. Instead of the slave cylinder I am using a Hydrolic Bering. Bleed the system, no problem. I can see the berring moving inside the bellhousing and pushing on the Pressure Plate. I believe that the installation was fine. I can not shift to any speed. As appear that the bering is working well, do not appear that it release the Clutch Plate. Any ideas?
Thanks
Thanks
