See how it reacts in manual 1st or 2nd gear. If it operates normal then I would venture to say its a soleniod issue as the manual select mechanically sends higher nominal pressure throughout the transmision. If it doesnt react then their is an issue with the pump/ pump shaft. This is all providing your fluid level is normal and that your filter is not obstructed.
Delayed engagement (4T65E)
Originally posted by gpse3400 View PostSee how it reacts in manual 1st or 2nd gear. If it operates normal then I would venture to say its a soleniod issue as the manual select mechanically sends higher nominal pressure throughout the transmision. If it doesnt react then their is an issue with the pump/ pump shaft. This is all providing your fluid level is normal and that your filter is not obstructed.
Well the gear box on my Monte reacts the same way as it augments the PC soleniod. The manual select still mechanically redirects for higher pressure.Lorenzo
Originally posted by robertisaar View Posti always wondered if the newer trannies did that as well... i know on the 4T60E, the line pressure triples(or close to it IIRC) just from droping the shifter from 2 to 1...
But I think rather than continuing driving this car and letting it "bang" into gear, you might want to replace and fix the part that is throwing the code... otherwise you will cause more damage you maybe can't fix so easily and cheap.
Originally posted by Joelfke View Postwell i think its a bit too late. it started at about 45k now ive got 71k on it. i kinda planned on ripping apart the trans as it is
Why do people do this? It's not normal so why on earth would you keep driving it.
Well it is nice that it had an effect but bad that it wasn't enough...One other tid bit, the forward servo might be damaged. It is the protrusion on the back side of the transmission. That protrusion is a cover that is held by 3 8mm screws. I you will not have enough room to get at it unless you drop the frame at least. If you get under the car you can see it.Lorenzo
Originally posted by Joelfke View Postbecause ive been fighting with the dealer i bought it from to warranty it but their lifetime powertrain warranty is bullshit. I dont have the means to replace the PCS in my driveway and i dont have 1000 to waste on someone at a shop doing it.-60v6's 2nd Jon M.
