So, this is all to talk about the Good vs Bad on all our possible options on the different getrag trannies. I'd like as much info as possible, including torque capacity and such, because i know you guys have it somewhere, and i don't.
We all know the 282 is a damn strong tranny. and pretty universal. What *I* know is that mine has a horrible 1-2 shift. when i race, people ask me if i missed a gear, because it takes so long to fall into 2nd. is my synchro just shit or is that the tranny itself? never really driven any other 282 cars hard so i don't know....
284's - Very rare, so not the greatest option. but they're very very strong, and built to handle high revs.... sounds great on paper but hard to come by in the real world. any Pro's that might make it worthwhile to try one out? how do they mount up?
F23 - the ones we can use came on 00-02 base cavalier and sunfires(anythign else?) i know to be easiest to swap you need the cables and shifter assembly, too. problems here are the clutches are exspensive, but that only b/c they come with a new slave, which by the way is internal so that's another thing to consider. Also, you need to weld mount brackets to the frame, it's nowhere near a bolt-in ordeal. you can get both frame brackets for 120ish so it's not that bad though.... who knows mroe about these?
F40 - Awesome, simply because it's the only FWD 6 speed that will bolt up. i assume you'd want the shifter and cables for this too.... how does this mount in a G6? is it a pair of frame mounts, like the F23's in j-bodies? Big issue is the heavy, aftermarket-lacking sotck clutch setup..... also axles. need mroe info on this one too...
Discuss. Pro's, Con's, impossibilities, etc.
