Before I found this site, I was looking around for what I could find on the 4T65E transmission. Turns out there's a great illustrated sequence over at the Bonneville forum:
But it wasn't clear to me that the bushings could be replaced separately. This guy did so:
But still had some difficulty. At some point I may end up trying such a thing, I wonder how putting the bushings in a cooler along with some dry ice before hand and warming the steel component to 270 or 300 degrees would ease assembly?
But if one is just interested in how whether you can replace the solenoids without pulling the trans, this site shows how. (Link hasn't worked for me but it gets you close, then look for the step-by-step drop down in the Twisted Tech category. From there you search for GM 4T65E solenoid shift valve replacement TCC/PWM EPC 1-2 2-3)
Hope that adds to your web surfing enjoyment.
