This is why I wanted to run through my trans.
All of these clutches had a dark ring on the bottom side. These clutches are for the Input gear or 1st, it looks almost like they may have been heating up/slipping.
And one of my bands has a nice burn mark right down the middle of it.
Left a hot spot on the drum, but no surface scaring
Also I went through my valve body and swapped out all the stock valves for the replacement Sonnax ones, and I'm glad I did that... Many of those were badly worn, and would get stuck in the bores. All cleaned up and swapped out and they all move freely.
side by side 3-4 and 4-3
The improved 1-2 anti-stick one
I did the 2-3 and 3-2 as well, and did the high ratio boost valves to replace my low ratio ones. Same as I did on my red car trans and I was pleased with the result.
So right now I'm just waiting for that kit to come in and I need to order a new low band which is only 9 bux, thankfully.
willyman, I'll get you a pic of the old TCC valve vs the new one with the teflon seal.
