I need the measurement for the distance between the flywheel mounting surface and the top of the pressure plate clutch release flanges, (where the throw out bearing makes contact) of a flywheel, clutch disc and pressure plate assembly.
Basically the 3 parts bolted together as if they were installed in the car, laid flat on the floor and measured from the floor to the top of the release flanges.
Working on a solution to the dual mass flywheel for the 6 speed trans.
Thanks
Thanks
