It's bolted into a Beretta, but I do not think it's from any Beretta... It's not a 2000+ Jbody, those look different.
1) Notice it is bolted down with rubber isolators, the whole thing moves when you shift side to side...
2) The select cable attaches at the far back, the cable was modified to reach there.
3) The shift cable does not really fit the ball socket on the arm which is large and fat. Worn out and won't even stay on now.
4) The shift arm instead of going straight up, goes up, angles almost 45* to the right, then angles straight up again. 4th and Reverse hit the e-brake handle...
What is this?!?!
What is this?!?!
