i know after 92 transmission mounts changed in some of the 660 five speeds. but im trying to find out how they mounted 282's in berreta's. is it the big upper mount like a z24 or is it the two mounts on the frame (body kinda framish) rail like a 96+ cavalier or nvg for a q4 motor.
berreta 282 mount
You have to weld them to the frame rail of the body, but the 92+ L body mounts are superior. Two opposing mount points instead of one pivot point means less rotation.
However your trans may not accept the mounts. Some have bosses for it but need to be drilled and tapped, others I *think* may not have bosses cast at all..sigpicNew 2010 project (click image)
I can't find pics of the setup- I forgot my login and locked myself out of bstuff. can someone post the pics here? welding isn't an issue and I'd rather have the better setup. I already sturdied up my mounts on the pass side by filling them with poly and I used some metal to help fill some of the gaps for less compression.88 Beretta GT
69 Corvette
79 Mustang Ghia
95 Cutlass Convertible
so, where did you get your mounts from? salvage yard? I wish I had my Beretta book here to look at. It's a gm parts book that's like a foot thick. I'll grab it from my parents house this weekend. That makes for a much cleaner looking install.
Oh yeah, where does it mount to the trans? got pics of the bosses?88 Beretta GT
69 Corvette
79 Mustang Ghia
