It turns out all the schematics I came across are inconsistent with eachother. I took the sidecover off and removed the harness. My 5 pin is equipped with the 2nd gear start as well. I don't really need it, so if its easier to delete it thats fine. I have the TCC solenoid, and 3 pressure switches, according to my 93 harness schematic the original 93 had 3 solenoids and 2 pressure switches. So the issue here is, is it even gonna work? I already know which wire color combo controls which solenoid/switch on my tranny. I just need to know which wires from my 7 pin harness to attach to each one...if possible.
Also on these, is following the ECM diagram according to A,B,C...terminals correct for all 4t60Es? If I were to assume E is ignition all the time? A solenoid A, B solenoid B? or does it vary with production?
