3.73 doesn't look too bad... but how to adjust the speedo is the question. Not running obd-II here.
Which is harder on a transmission?
VSS road speed constant.
Read this, to get an idea
You may want to go to that PCM in that guide there. It will shift a 4T60-E........ Then you'll have more options and can change shift points.........sigpicNew 2010 project (click image)
I'm running the comparable 3.69 ratio since I'm using the better 3.29 version of the 4t60e. They upgraded the roller sprag and a few other things and then that resulted in a 3.29 diff. I have the 33/37 chain set and I average about 2500 RPM at 68mph, and that's with a 25" dia tire. TCC locked btwLast edited by 3400-95-Modified; 11-18-2009, 11:32 AM.
Any suggestion on what applications the 3.29 would have been used? Also what are the electronic controls on the 60e? It seems from what I have read the 4L60e is more advanced than the 4T60e... is that correct?sigpic
- Ben
4l60e is a RWD tranny, hence the L = longitudal.
4t60e is a FWD tranny, hence the T = transverse (could be RWD, but it's still meant for mounting sideways)
if by more advanced, you mean it uses a pressure control solenoid in place of a vacuum modulator: yes.
-E on a tranny means it uses shift solenoids and the shift points are determined by the PCM, as opposed to back in the day, using a TV cable to control when and a vacuum modulator to control how hard. an example of that would be a 4t60.(440T4 depending on which GM docs you read).
some -e trannies don't actually have a -e in the name, the 4t80 and 4l80 being two i can think of. since there were never any old styles of those trannies, the -e is irrelevant. confusing, but unnecessary.
I understood the L and T, I just meant that even though they were both 60e transmissions that they weren't of a similar feature set.sigpic
- Ben
Originally posted by carbon View PostI understood the L and T, I just meant that even though they were both 60e transmissions that they weren't of a similar feature set.
Would anyone happen to know where to get the specs on controlling a 4T60E or 65E tranny on the interwebs? I would be interested to know what it takes to run these, things like PWM inputs and such...sigpic
- Ben
for the 60e, it's just the shift solenoids and the TCC, PWM on the last one if your torque converter can do it(any can, but there is a specific clutch material meant for PWM applications... those are all either 12 or 5 volt.
65e: now you have to deal with the pressure control motor. i can't tell you anything about that.
I wouldn't consider it for a daily driver. 3500 RPM at 70 MPH can be a PITA.
Normal for fiero on the highway is abut 70@3-3500rpm i'm pretty sure.
Car has been parked a month so can't remember for positive but I regularly drive on the interstate at 4k rpm for 30m or more.
Just thought that was funny,lol.
Originally posted by carbon View PostWould anyone happen to know where to get the specs on controlling a 4T60E or 65E tranny on the interwebs? I would be interested to know what it takes to run these, things like PWM inputs and such...
Originally posted by IsaacHayes View Post3500 @ 70 in a Fiero? Must be the 4-speed manual.
