need help: swapping backwards 4t60-e to 4t60
  • need help: swapping backwards 4t60-e to 4t60
    i have a '91 caddy with transverse mounted v8 and 4t60-e that is bad. i have a donor car '92 euro with 4t60. need to know what is needed to pull off this swap. if i mount the throttle valve linkage will this do it?? the wire plug is different on the 2. thanks......
    You will also need a passenger side axle. 4T60's typically use a longer axel.
    Lorenzo
      what about re-using the caddy axles?? i do have the euro axles still in the 4t60. im mainly concerned with the operation of the 4t60 in the caddy without the plug plugged in because it is different. will it shift right?? do i need to splice the correct plug onto the wiring in the caddy??
        As long as the TV cable and vacuum modulator are hooked up it will shift. But if you want the lock up converter then you'll need to contend with the main wireing harness. As for the axles I cant say that the length will be correct/ you are better off finding an axel to that car at a time it ran with a 4T60/ 440-T4.
        Lorenzo
