I've found sfi approved flexplates for the older 2.8L rwd engines that are external balanced, but these work on a gen3-4 engine if neutral balanced? Just hoping to find a flexplate plate that will hold up a little better and be a little safer than just spinning a stocker up to 7-8krpm and praying it won't fly apart and the bellhousing safety plate holds. Searched around for answers and no luck so far.
SFI Approved Flexplates?
98 camaro swapping in lz9 th400 setup
LZ9 specs: (Subject to Change work in progress)
4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.Tags: None
Have you emailed anyone like TCI and see what they say, or have available?-Brad-
Actually scratch that I just found an internal balanced sfi approved flexplate for the rwd application 2.8L. Little leary about it, but for the cost its worth a shot.
