Im looking for an aluminum flywheel and clutch kit or any other performance clutch parts for my 93 lumina Z-34. Does anyone know where to find this stuff?
Where can i find a flywheel and clutch kit?
Tags: None
i dont think theres a aftermarket flywheel for the 284.. You can pretty much only get a aftermarket clutch..Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built car
Originally posted by steevnz34 View PostSo you are saying these guys that have fieros with the 3.4 dohc and are using fidanza aluminum flywheels are full of it? or is the flywheel matched to the tranny and not the engine?Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Originally posted by 94GPGTP View Posti dont think theres a aftermarket flywheel for the 284..Originally posted by 94GPGTP View PostThe lightweights are for 282's. All the 60v6 flywheels will interchange.
Originally posted by 94GPGTP View Postyea the flywheels are matched to the tranny.
The Rockauto.com listing for a Rhino Pac flywheel for a 92 Z34 (284) lists these vehicles that their flywheel will fit in:
CHEVROLET LUMINA 1990
CHEVROLET LUMINA EURO (1990 - 1993)
CHEVROLET LUMINA Z34 (1991 - 1993)
CHEVROLET S10 PICKUP (1994 - 2003)
GMC SONOMA (1994 - 2002)
ISUZU HOMBRE (1996 - 2000)
OLDSMOBILE CUTLASS SUPREME 1991
OLDSMOBILE CUTLASS SUPREME INTERNATIONAL (1991 - 1992)
OLDSMOBILE CUTLASS SUPREME S 1992
OLDSMOBILE CUTLASS SUPREME SL 1991
PONTIAC GRAND PRIX (1989 - 1993)
PONTIAC GRAND PRIX GT (1991 - 1993)
PONTIAC GRAND PRIX LE (1989 - 1993)
PONTIAC GRAND PRIX MCLAREN 1990
PONTIAC GRAND PRIX SE (1989 - 1992)
PONTIAC GRAND PRIX STE (1990 - 1993)
And we all know, any W body that got a manual that didn't have a 284 was a 282 (which would account for the 89-90 GPs) since the 284 was only used from 91-93 (in the Z34, GTP, STE and Cutty INTL.).Last edited by pocket-rocket; 09-25-2009, 02:03 PM.-60v6's 2nd Jon M.
I wouldn't go with that light wieght flywheel if your using it in a w-body because of the wieght of the car VS. the power output, unless you have a lot of power, otherwise you will regret it after. I've seen it first hand.
If your building a turbo 3.4 DOHC and have the power, great!1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
Originally posted by HayesPerformance View PostI wouldn't go with that light wieght flywheel if your using it in a w-body because of the wieght of the car VS. the power output, unless you have a lot of power, otherwise you will regret it after. I've seen it first hand.
i will try to bold my spare 282 pressure plate to my 284 flywheel.. if it does then the lightweight 282 fylwheel will work on the 284..Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Ok so heres my input.. The 282 Pressure plate bolts to the 284 Flywheel.. So therefor the flywheels are the same.. But... Now with the Fidenza Lightweight it has a removeable insert.. The clutch disc for the 282 is smaller than the 284 and the 284 uses more of the flyweel than the 282.. So is the insert for the lightweight big enough? i see that the wear marks on the 284 flywheel are pretty close to the edge where the bolts are for the pressure plate and since the 282 disc is smaller its further away from the bolts for the pressure plate.. Thats y im thinking possibly the insert might not be big enough.. Heres some pictures..
Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
ive heard a bit about the fidanza flywheels shearing off & slicing through the trans casing/flying out-not sure if its true but thats enough for me to stay away!
also if you havent watched this video-its great info
