Making Getrag 282 Mounts
  • Making Getrag 282 Mounts
    Seeing how these mounts are discontinued and any existing one is probably flimsy/ on its way out, me and a highly skilled professional welder buddy of mine are going to make solid transmission mounts for my w-body 282. We are going to start out with about 20 for the first batch! The plan is to use 1/2 inch hardened rubber/poly material as shock absorber and the rest of the mount heavy duty mig welded solid cast iron construction for increased durability , ultimatley preventing unwanted movement. Black texture coated ,stainless steel studs welded in place and SS nuts will be included.
    Edit* These mounts are on the way, will update with pics when done. A lot has gone into these to ensure high quality. They are going to be really nice. stay tuned.
    this could be interesting......
    how about a poly shock absorber instead of rubber?
      Thanks for the suggestion. Im going to be hunting around for best suited material for the shock absorbant.
        if i knew where i could get polyurethane, i'd make them myself .
        poly motor mounts seem pretty popular and keep the motor from moving a lot better than stock rubber ones. thats my basis anyway...
          interestingly enough, in my search for how to get poly, i found a recipe for making condoms from canola oil...
            You think that material would provide enough flexability?
              a mount shouldn't need THAT much flexibility, depending on what kind of tolerance you're working with. could always contact the company and see what they think...
                Energy Suspension bushings are poly and come in a few different sizes.
                  my dad actually has a set for his Nova.... if i remember, i'll check sizes on them next time i see him.
                    I would definitely be in for for one. Mine's toast.
                      vintage parts should still have a few 282 mounts left, but they aren't exactly the cream of the crop.. mine wasn't anyway.
                      -Tony | gtsdurango.net
                      '04 Dakota Quad Cab SLT 4x4 - the gas guzzling DD.
                      '90 Turbo Grand Prix STE - ehh.. I'm working on it.
                      '92 Gutless Supreme SL - RIP 5.2010
                      '90 Turbo Grand Prix - RIP 6.15.2005
                        I did something like this for my 284. I burned the rubber out of a stock mount, welded in some frame work to the 2 pieces and filled with polyurathane. The framework purpose was to 'hold' the poly in place rather than rely on its bonding to the walls of the mount. It works great. I also replaced the pin that goes through the mount. After the original rubber let go my car decided to snap that pin.
                        1994 Corvette
                        LT1/ZF6
                        2006 Dodge Dakota 4x4
                        3.7/42RLE
                          id be in for one.. who knows how long my tgp will let this one last..
                          Robert
                          New Rebuilt 3100
                          New Rebuilt 4T60-E
                          Exhaust
                          Drilled/Slotted Rotors
                          White
                          3" Magnaflow Catback
                          90 Pontiac Turbo Grand Prix
                          5 Speed Swapped
                          127,000
                          Spec Stage 3 Clutch
                          230,000 mile Getrag 282
                          Emissions Deleted
                          Brand new Engine 1,000 Miles
                          Fully Custom Built car
                            Not not work but check the poly leaf spring bushings.
                            87 3.4 4x4 blazer
                              Bump to top^^^first post updated. Sorry for the long delay. These mounts will finally be in the making!
                              * Also 284 mounts COULD be easily available, we would just need one to take measurements from.
