Hi all.
(Newbie here)
What is the proper method for reseating a metal line into the accumulator(?) in a 4T60-E? Any special techniques.. or do I just try to give the bugger a good shove back in?
I dropped the transmission pan in my '96 Ciera SL (3100, 4T60-E) to do a drain, filter change and fill. (Only used two newspapers for sopping action when the pan slipped...
) I noticed that there was a loose line flopping around when I was removing the filter. I'm nearly positive I didn't bump it out.
After a bit of research, I believe that it's one of the three lines that connect to the accumulator.
I'm pretty sure that I need to properly reseat that line. Unfortunately, my repair manual only shows how to change the fluid and drop the transmission... nothing more.
The other ends of the two lines that are still connected to the accumulator are attached to some other assembly. The line that that is disconnected seems to be attached to some sort of swivel and has a short rubber hose in the middle.
Thanks
Thanks
