95 4T60-E to replace a 93 4T60-E, what do i need to do?
  • 95 4T60-E to replace a 93 4T60-E, what do i need to do?
    So ive got a 95 4t60e that Im using to replace a 93 trans, what changes were there internally that I have to worry about? I am aware of the different side case, but that is not a problem.. i really just need for the 93 ECM to run this thing correctly.
    I modify stuff
    You will find there is alot of difference with the electronics, the number of pins and so on.
    If you want some help and can wait a bit I can pass on a connection to talk with.
    Ty
      im running a 91 trans with 94 computer/harness, i had to change every wire on the trans plug
