Hello everyone!
I have a 99 Chevy Lumina 3.1L with a 4t60e with about 210K on the clock. Recently I have tried to solve a snap noise from the drivetrain. In doing so I replaced almost all of the suspension (worn and needed it anyway) as well as the CV shafts (which were in decent shape despite the mileage). Anyhow the snapping noise that would happen on hard acceleration from a dead stop, or hard braking has turned into a bad vibration at speeds above 30 MPH.
I put the car up on stands and ran the car in gear to try to find the problem. If only one wheel (the passenger) is spinning there will be no vibration and everything is well. As soon as the speed is high enough both tires will start to spin the whole motor and transmission assembly starts to vibrate badly. The car still shifts fine, and the trans does not slip.
This has led me to think that the differential is bad, especially since I systematically elimanted the other elements by throwing new parts at it. My question is how to remove the differential without dropping the trans out of the car. Can I simply pull the right side CV shaft and differential housing cover then just pull the carrier out?
Thanks,
Mike
Thanks,
Mike
