125c
  • #16
    I can remove my pcv tube fairly easy and also remove the rear valve cover without removing the plenum....... I can also do it without removing the ALT!
    • #17
      Now this i'd like to see!
      • #18
        Just ask bve, sure the car isn't fully stock under the hood, but neither are anyone elses that swapped engines.
        • #19
          He is telling the truth! He can do all that without taking anything apart. Now the trick is to see if he can do it all on a DOHC. haha
          • #20
            There is no way you can remove the PVC in .5 second if it has that stupid riveted clamp on there.
            What the hell is that all about?
            • #21
              All that^ guys fault!
              • #22
                The pump behind that stamped cover it would be very easy access and make adjustments, providing you have clearanace. But I don't know what clearance you guys have on J and L bodies. I would like to think you can do it on the car. I know a longer intermediate servo pin should firm up the 1-2 as it will apply faster.
                Lorenzo
