trans ratios
  • trans ratios
    does anybody know what the gear ratios are on a 2.8 v6, 93 Gmc Sonoma, 5 speed. I believe its a Borg warner tranny. Is there a better tranny that can be swapped in?
    Check the BW T5 tag to confirm?
    Likely this one:
    1352-222 GM 1993 MY S-Truck 2.8L WC 3.97 2.34 1.48 1.00 0.72
    (1st, 2nd, 3rd, 4th, 5th) and a 3.70 reverse
      still wondering
      the tag is 1352-234. I found a web site that has the tag numbers for most of the bw tranny's. Most except for mine, lucky me. It does say that mine is a GM 1993 MY 2.8L. But it doesn't say if it is a world class or not. And I forgot what the front of the case looked like when I did the clutch last year. Anybody got anymore ideas?
        That would be a world class version.
          1352-234 is one of the few not listed. Most likely a newer S10 has the 3.76 1st gear ratio and if you have a 3.42 rear end ratio, thats a decent combo.
          -BMC.
          MG & MGB V6 + V8 Engine Conversion Shop
          1982 Chevrolet S10 long box with another L32 SFI!
          1980 MGB with Camaro L32 3.4L SFI V6
          2000 Venture 3400 (for her)
          Spitfire L32 3.4L
          "Experimentals"
          and more conversions all the time.
