92 cutlass supreme 3.4 , 4t60e removal . Help!!!!!
  • 92 cutlass supreme 3.4 , 4t60e removal . Help!!!!!
    Is it possible to remove this transaxle from the bottom , and what is required to do it ? I have taken about everything loose but can`t get it to drop out the bottom . Does the frame drop out of this car ? Thanks for any info !
    You'd probably have to remove the subframe. And did you remember to unbolt the torque convertor from the flexplate?
      I did this a coupla weekends ago...Prolly one of the easiest things I've ever done on my car. Make sure you remove all of the bolts from the "bellhousing" and like bszopi said the bolts that connect the flywheel to the torque converter. Drop the sub frame, pull the axles and disconnect the tranny from the mount. If the trany moves freely, you might need to shake/rock the tranny and pull it away from the engine. Keep in mind that all of this was on a '91 beretta with a TH125 auto tranny, and it might be harder for your car. Hope this helps
      1991 Chevy Beretta GT auto
      Rebuilt engine - Crane H260 cam, crane springs and retainers, ported intake and custom WAI.
      Dual rear sway bars, strut tower brace, and poly end-links. I\'ve got reverse now, but she\'s making me sell it
        I know some guys think replacing a 4t60 is "not that bad" but I could name a hell of alot easier jobs such as replacing the alternator, tail light bulb, checking the oil etc. Anyway check this link cause i was originally going to do mine from the top untill I figured out the master cylinder would have to come out. Ended up out the bottom with a floor jack.
        2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
          Got it !!! Thanks for all the help guys .
          Took the sub frame down and everything was great from there on out . Thanks to all the posts for the help !!!
