For 3 years I've been running an MK7 mated to a slightly modified 3400. Recently I acquired a new Z24 that was already 3400 swapped with an auto, and an HM282 with all swap parts. I sold the 3400 in that car and swapped in my 3400 from my old Z that had the MK7.
The 282 sat dry for about 5 years. When it was out of the car, the input shaft spun freely, and the shift select levers shifted easily and smoothly. It currently has a clutchnet 6 puck ceramic clutch with a clutchmasters PP. The flywheel is the same one I used with the MK7, which originally came from a 4 banger. I'm pretty sure they are the same between i4 and v6 correct? Anyway I also installed a new TOB as well.
So I'm ready to start the z24. Transmission is in neutral, all is ready to go. I start cranking to build oil pressure. For about 30 seconds all is fine, and then a horrible screaching noise is coming from the transmission, bell housing area. Frustrated I give up for the day.
I've come to realize that it's usually fine for the first 30 seconds. But then the noise happens every time I try to crank it untill like the next day when I try.
Does anybody have any clue what's going on at all? Any help would be appreciated.
Jay
Jay
