quick help needed, helms manuals lost in fedex hell
  • quick help needed, helms manuals lost in fedex hell
    I got a new 4t60e fro the GA and I am ready to put it in tomarrow morning but the manuals I ordered (and paid $50 for next day dilevery, grrr ) didn't arrive!
    I need to know those little tricks
    how high do I have to get it off the ground?
    how do I support the engine?
    do I undo all the S__T they say?
    help
    Take the subframe out along with the shocks. Then unbolt the tranny and any cables and wires attached to it. It sould come out fairly easily with the subframe out.
      thanks, I got it changed. It turns out that the 95 has 2 half-sub-frames that only hold bottom suspension. It was not to bad of a changeout,just had to use cherry picker to suspend motor while pulling tranny. The problem was almost needing 2 cherry pickers or 2 tranny jack because how do you swap trannys on tranny jack while engine hoist is supporting motor :-) Now if I can just get the neutral safety switch adjusted, I'll be happy, it is soooo smooth now. There are some little quirks to change tranny so if anyone has questions ask now.
