Anyone know what the pulse width frequencies are for all of the PWM solenoids in a 1998 4T65E? Are they the same for all years, and are they the same for a 4T60E, or even the 4T40/45E?
PWM Frequencies - Any ideas?
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
62mm TB, 1.6 roller tip rockers, Ostrich 2.0, UD pulley, TB heater bypass, K&N, 180* stat, No cat, 99Grand AM dual cooling fans. 4T65E swap FDR 3.69, EP LSD, F.A.S.T. transmission controller, TransGo shift kit.Tags: None
I found the TCC duty cycle on a 4T60E at 32 Hz. Mine was set at 68 Hz. It's now at 24 Hz and TCC lock is finally smooth! No more lookin like I can't shift into second gear with a 5 speed! lolAndy
