Im new here and im just curious if anyone knows any company that makes a high stall torque converter the 4t60e/lq1 combination? Any help would be great!
3000Stall converter needed for Z34 Lumina
Yank used to make them... I would give them a call and see if they can still do it... If not I know Jeff From Engineered Performance can get you a HD one made at the stall you want.
There is an old GM 4 speed converter which is pretty close to 3000 rpm stall. You could try that. Bonus- it's a factory part and they're cheap.
Tim1995 Z34 - T04E "60" trim, 42.5 lb/hr injectors, AEM WBO2, FFP UD&DB, 3" exhaust, 2800 stall, shift kit, tranny cooler, Powerslot, Hawk HPS, rear disc conversion, KYB, Eibach, HMS F&R STB, Fittipaldi Force 18" wheels, big stereo, lots more coming eventually...
325 whp 350 lb-ft
