04 Monte Carlo LS
  • 04 Monte Carlo LS
    1
    you can try teh band aids, but if its slipping, its usually burned clutches, although sometimes a good fluid filter change will do wonders...then if still messes up use some lucas or bars or trans x if you wish
      I love the Lucas Oil Stabilizer, but the trans stuff makes me cringe. Made the TCC in the old 4t60-e in the 91 go nuts. Half the time I had lockup, half the time I didn't. Then when it did go in, half of that time it would slip, so I would have to let off to disengage it and get back on the gas to re-engage in hopes it wouldn't slip if it did go back in.
