I have a 94 Cavy 3.1 with a 3 speed automatic transmission. I know they also make a 4 speed automatic. Has anybody made the swap from the 3 speed to the 4 speed? Would it just be a swap and go, or would other components need to be swapped also such as the computer?
Transmission
4 speed is electronic unless you go with the 4t60 non electronic version... Now if that swap has been done I dont know, I would assume you would need some motor mount work done unless the 94 cavi uses the same side mount.
Either way I can't imagine it being a swap and go project.
The 4 speed (non E) uses W body mounting since those transmissions were found in the TGP application. I don't know of anyone currently with a successful swap, but I would imagine it is more possible to accomplish than a 4 speed-E trans swap. The 4 speed would be better for highway use, but imo, when you compare the 3t40 with the 4t60, they're both pretty weak at handling more hp/tq. If one were to want to have just a street/performance trans made out of the two, I would suggest the 3t40 since it doesn't weigh as much and much simpler design. If you're looking for highway use with performance in mind, then the 4 speed is the way to go IF you're willing to chop/weld in some new mounting brackets.
.02Lifting my front wheels, one jack at a time.
4T65-E swap has been done in a 90s J-body, so it is entirely possible. There is a thread around here somewhere about it...
