I'm working on swapping in 1993 Isuzu 5spd from 2.2 Beretta to my 1992 3.1 MPFI Automatic Beretta,
I was planning to replace the clutch to new on white at it, and i noticed Centerforce has different part numbers for 2.3 & V6 vs 2.2 clutches.
1) What is the difference between those clutches then? I thougt the 2.2 clutch & flywheel bolts up just fine(?)
2) Centerforce & Spec tells that you Need to install the clutch on new or resurfaced flywheel, how Must this really is?
3) Does the Centerforce Dual friction disc come with new throw-out bearing?
Thanks
Thanks
