Manual tranny swap/Dirt car Grand am GT 2000
  • Manual tranny swap/Dirt car Grand am GT 2000
    Hi guys..
    I m racing on Dirt for the last 4 years with a Z-24 v6. Won championship last year with some of your performance advices.. Thanks.!!
    Planning in replacing that old CAV. with a Grand am Gt with a 3400. (have to use the original motors so the Gen 2 are some what short on HP and torque)
    Can the manual tranny from the CAV will fit on the Grand Am?? What about the axles??
    Would the ECM be able to handle that modification?? without a lot of wire jumping??
    Waiting for your answers!!!
    Thank s..
    dont know if its exactly what your looking for but heres a detailed how to on how to swap a 6 speed from a G6 into a Grand Am GT
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
      What year grand am? As far as i know it whould swap right in and all the drive shafts and such should line right up.
      You will only run into issues if you have a 99+ grand am because a lot of changes happened then. You would have to use the outer ends of the grand am drive shafts because the splines on the hub are larger. and I'm not sure about the width... i'm pretty sure it would be ok but i am not certain.
      Also check the tranny mounts, I doubt the cavy would have the front trans mount (only uses a rear) and I would think the grand am uses front and rear trans mounts... again I'm not 100% but its something you can easily look at and confirm as I know these are the common problems with swaps into other cars.
      hope that helps
      Mr_Efficiency
      90 Grand prix - Lawn ornament
      Black, 3.1, 5 speed
      Future holds: Striped and then scrap yard
      97 Cavalier - Stock car
      Red/Black, 2.2 OHV, 5 speed, fully tubed bumper to bumper, 6 point cage with halo, fuel cell, race seat, 5 pt harness.... a race car
      Future holds: Just more trophies
      New project on the way: 88 S10 reg cab, short box, 5 speed.
      Future holds: Built 2.8 hybrid, Stealthy flat black, a drop until i have no more ugly wheel gap
        that was done on the 99+ Grand Am with the G6 six speed and he has a 2000 grand am.
        with the six speed the 6th gear is basically for highway cruising kinda like an overdrive in an auto.
        99 Grand Am GT
