Hi folks i'am new here I drive a one ton dually but fuel prices down sized me. I have a 1996 olds cutlass with a 3.4 engine and a 4t60 e trans. runs and drives great it just doesn't go into overdrive. any ideas? The SES light is on with a 1870 code
No over drive
is it not going into overdrive (4th gear), or TCC lockup? If it's the latter, it's usually caused by a bad Pulsewidth modulated solenoid. If you go ahead and disconnect it, it may start working again. Let me know and I'll find some data to help you.Brian
3400 SFI V6, 4T60e
It's a black wire, I believe Pin E on the transmission connector (under the engine airbox) This site has a diagram showing this but I can't seem to find it. It sounds like it isn't your problem though, but maybe it's worth a shot. If you just pop the pin out of the connector, and it doesn't change anything, just slide it back in.Brian
3400 SFI V6, 4T60e
Brian
3400 SFI V6, 4T60e
Just got back from a roadtrip to Minneapolis. On the way back I had a similar issue pop up and the transmission wouldn't go into full lock at cruise speeds. Turned out I was just low on fluid after one of my BRAND NEW fluid cooler lines (OEM-style) decided to leak. Thankfully it was just a slow leak and all I needed was 2L over a few stops to get everything working right again. Not sure what to do with the other 6L I bought incase it wasn't a slow leak.1995 Grand Am SE
Save them for your next scheduled filter change :P-60v6's 2nd Jon M.
common issue...
74k miles on that one, and ready to strip with a little more power... needless to say I replaced it when I rebuilt the trans.
did the fluid have a orangish tint to it when drained? if so bad torque converter... I have a E with that problem and just spent 1250 instead and got a E rebuilt.. didnt want to take out the converter to replace and later down the road have more problems..Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built car
Looks like I'm still having OD problems. This morning the car struggled to get into overdrive and keep it. On the way back from work though it was working as it always had so I'm a little confused. Fluid is still full and hasn't leaked so all I can think is either a sticky TCC solenoid or there was some more air waiting to bleed out of the system.1995 Grand Am SE
If it comes and goes then your in good luck still. Check or change out the gear selector switch on the trans. One way to test to see if its out of range is to shift it into OD and go up to 50mph. Then ever so slighly try to move it up or down without shifting it into Nutral or Drive. DID you run a scan of the car?88 Beretta GTU turbo . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
