Need nvg 550 help, asap.
  • Need nvg 550 help, asap.
    Im currently splitting my cases. How do I release the input shaft from the bellhousing!?! Its ready to split, but the input shaft is hanging me up. I know a few guys on here have done it....
    Thanks
    95 Beretta- Lg8 Daily Driver
    The input shaft shouldn't bind on anything. Sounds like you forgot some steps..
    Did you remove the detent cover and assembly?
    Don't forget the bushing on one of the shift shafts (I think it's on the reverse shaft? I forget..). You can walk it out with some allen keys or small prybars. It seems ridiculous, but you seriously can't get the cases apart without removing it.
      ^^ x2
        Very intresting. I did everyting, But I couldnt get that bushing out. I even made my own puller adapter for my slide hammer...
        I really thought the reverse shaft would slide out of it though...
        Thanks for the help. Any tips for getting that bushing out?
          i use 2 small allen wrenches and soak the whole bushing in PB Blaster.. then use a tapping hammer to tap the allens and slowly pull it up and out.
            Alright. Ill soak it now, then ill give it another try when I get home.
            Thanks
              i would say remove the detent cover, inside there are some steel balls and springs the need to be removed. (that was my hang-up too) WARNING, try very hard not to damage the detent cover, since it is a discontinued part from gm.
                for the cover i just knock out the center hole and pry it out with whatever i can find... then flatten it back out and use that aluminium ducting tape over both sides of the hole (with the cover cleaned very well). It seems to hold up very well.
                  Well guys, I let the bushing soak in wd 40 while I was at school today. Came home, and walked it right out.
                  The cases came apart easily. I cant beleive that bushing was holding me up so bad.
                  Everything looks fantastic internally, however, it needs diff bearings, and im going to do seals all the way around. The diff bearings are still tight, but the race is pitted. So now I need to get bearings. I guess ill start at the dealer.
                  Does anyone have any part #'s?
                  Thanks
                    I think the races are 7455633 and the bearings are 7455634. Well, those are for the 282, but they should be the same. They're not on GMPD or VPI however. Part numbers could have been superceded, those were '87 numbers.
                    -Tony | gtsdurango.net
                    '04 Dakota Quad Cab SLT 4x4 - the gas guzzling DD.
                    '90 Turbo Grand Prix STE - ehh.. I'm working on it.
                    '92 Gutless Supreme SL - RIP 5.2010
                    '90 Turbo Grand Prix - RIP 6.15.2005
                      Timken SET 11 for the diff bearings.
                      Make sure you check and set the preload one way or another. You are shooting for 3 thousandths preload. Too much or too little and you'll be taking that thing apart again in a few months.
                        Any ideas on how to check my preload? Where can I get the shims to set it?
