4t45e shift kit
  • 4t45e shift kit
    Does anybody know if there is a shift kit for a 4t45e?
    all your going to find is an electronic module such as the auto trans interceptor or the B&M shift improver, you can either go that route or get a computer tuner which opens up a lot more possibilities
      ok but do they make one specifically to a 4t45e because I can't find one
        Probably not I searched and I couldn't see one either... Your best bet is a tuning solution via that you can change shift times and shift pressure, they are more configurable than my 60e is since my fluid pressure is regulated by vacuum and the valve body springs.
          how would i go about doing that?
            either find a used DHP unit or buy a HP tuner if it supports your car.
            ive done a greta deal of tuning in DHP for the tranny side of things. just fixing the shift points and raising the fluid pressure will help.
            HPTuners, VCM Suite, MPVI, MPVI2, VCM Editor, VCM Scanner, tuning, OBDII vehicle
            i dont think a shift kit exists for the 4t45 but there are a number of people who have been deep inside one on this board alone.
            gectek
            tehjohnson
            theres a few more but i cant remember right now
            99 Grand Am GT
            1357 cam 227 233 .050 dur
            515 515 lift 112 lsa
              what kind of places do that kind of stuff?
                i dont know of any. probably just have to pick up the phonebook and go through it till you find some place if you end up finding someone.
                99 Grand Am GT
