Just a note: Thinking outside the box as I sometimes do, I used some engine valve springs I had laying around when I did this. Worked very well. The washers I got from Home Depot in the bolt section. Just bring your parts with you and see what will drop in the hole.
4T60-e shift Kit?
DRY transmission, Freshly built, with no converter weighs in at 161lbs with side motor mount on.
Converter is 20lbs dry...
So I would say add about 10-12 quarts of fluid to that, and thats your total trans weight. The converter can hold like 3-4 quarts I THINK... and when that comes off the fluid doesn't drain out of that easily so even dropping the pan your only getting out about 5-6 quarts of oil... so yeah. It's heavy.
Dry with converter the trans weighs just about what I do... and it's shaped like a friken beach ball with a 80lb leg...
Damn!! Weighs more than a TH350/TH400!! (but does have the diff inside too)sigpicNew 2010 project (click image)
the diff isnt THAT heavy... Maybe 15lbs if that. Also remember a TH350/TH400 is a straight shot, this one has gears and a chain, and probably more case material too.Last edited by 3400-95-Modified; 03-04-2008, 04:03 PM.
Yup, the TH350/TH400/Powerglide one I have on mine. It fit's other trans too but yeah..sigpicNew 2010 project (click image)
I don't think so, it was discussed once and I think we figured it wouldn't work for the 46t0-e, since it's vacuum controlled line pressure.
I have the adjustable pioneer one from o-reillys, with it turned in 4 turns from where it's at out of the box (max it recommends) and shifts are nice and clean, not too harsh at part throttle, and I have a poly insert in my upper mount even.sigpicNew 2010 project (click image)
3400Modified....Where On The Diff Is The Tag To Tell Me What Accum I Have? I Can Only Get Under Half The Car Because It Is So Low. I Don't Want To Start It Just To Move It (I Have To Drive It On Blocks To Set A Jack Under It). I Can't See Any Tag Or Markings Anywhere. And My RPO Code Doesn't Say Anything.
Passenger side, between the firewall and trans, there should be a metal tag on the trans. It might be aimed up towards the sky a bit.sigpicNew 2010 project (click image)
