so can i grap a trans and pcm out of a 97 or 98 venture??
3.33 swap
1996 Beretta
3100 SFI TURBO
13.1 @ 103 mph best in the 1/4 mile
I would have to reverify that the 97 venture bin file works stock for stock... and NO a 98 wont work, ONLY the 97 Venture ECM is plug and play with our harness and wiring.
ok if the 97 works i dont need to tune it because the pcm is set for that trani right?
1996 Beretta
3100 SFI TURBO
I will get back to you on that one today.
Your still running a small port 3100 right?
no im running a 3100 large port. i swapped to 3400 manifolds, 3800 tb.
1996 Beretta
3100 SFI TURBO
3800 TB? Huh? Pics? What's the diameter? ?? You made an adapter?
The 3400 code should run your large port 3100 ok. If a small port program can run a 3400 ok I'd say it could adjust to .3L less displacement good enough.
That is if everything else works for other stuff in the car.sigpic New 2010 project (click image)
the tb is a 3400 bored out to the size of a 3800. i put a 3800 butterfly in it.
1996 Beretta
3100 SFI TURBO
I dont know if the stock venture code works, I pulled my 97 ECM on my 95 so I could go back to the 96 one and see if I could get mileage back since there was no point running a 3400 code on a 3100 small port.
I'll test it once I get some free time but I think the factory venture settings are set for 3.33 or 3.29 so it should shift ok.
kewl thanks
1996 Beretta
3100 SFI TURBO
