looking for a posi?
  • #16
    Now i have to get these damn contractors to pay me so i can one.
    68 El camino 454 speed muncie 3.90 posi 12 bolt,
    80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
    60 Impala 2 door hardtop L79-327 T56 4.11 posi.
    83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
    91 Z34 now has a hm284. and belly pan in the works
    • #17
      jeff will do it. he likes the 284 and studied it to a certain degree and iirc he actually has a 284 w-body or had at one time.
      i was going to get him to do it but you either have to send him the transmission or remove the diff and send it to him. he does not have any cores so he will need yours.
      i was going to do it but i never found a standby 284 to send him.
      • #18
        well just bought a 92 Z34 that runs but has been wrecked and some title issues but it has a hm284 and I'm going to convert my auto over to it. but first i'm going through it and replace all the synchros and bearings and all that good stuff along with rebuild the other motor with alot of tweaking
        • #19
          night and day difference between the auto and the manual. 1 problem with your theory though. there are no parts available to replace the bad ones. only way to get this rebuilt is to send it to getrag gears of north america.
          if you need a clutch or pressure plate i have a stock set with low wear i cann sell you cheap. the stock clutch is actually pretty good in design.
          • #20
            I heard that the bearings and synchros where the only parts for this transmission that you could find other than a clutch
            • #21
              there is more than that available.
              a neutrally balanced flywheel for a 282 from 88+ will work and as far as i know 1 company called clutchnet makes aftermarket clutches and pressure plates. they sell 2x pressure plates.
              they are costly but they good parts IMO.
              where can you get the bearings and synchro's from i wonder?
