Cadd Drawings
  • Cadd Drawings
    To anyone willing to help. I'm working on an adapter to mate an AX15 to an SAE3 bellhousing, and through searching have found this site. I'm under the assumption my Dakota bellhousing matches the GM 60 degree. Basically my question is , does anyone have info such as CAD drawings (or links to such info)of the face of this 60degree bellhousing? I can measure the dowell holes with 24" calipers, but getting the center of the input shaft is another issue altogether. I will continue to search this site, and maybe find out that I've asked a stupid question.
    There is one, although it doesn't really have the bellhousing bolts on it. I have another one around here somewhere....
      Here we go. This is from a 3500VVT, but the bellhousing pattern hasn't changed from previous versions.
      EDIT: Just re-read your post, and not sure this is what you really need. But hopefully it will help?
