So in my manual it lists the pressure plate to flywheel bolts (6 of em) as only needing to be torqued to 15 ft/lbs plus 30*. That seems AWFULLY weak for a clutch.
Can anyone confirm the actual torque spec? Is that correct?
Normally I wouldnt bother asking, but I dont feel like pulling a tranny and replacing a damaged clutch if one of those bolts works its way out.
