If the transmission you posted the pictures of is the one you bought to replace your 1996 one, then you will also need to swap out the side pan. That one has the stamped steel one. Your car will have a cast one that has the transmission mount attached directly too it. Just get a new gasket (there are 2).
You can just swap out the park neutral switch (the one on top with the wires coming out of it), and the side pan, and it will swap right out. The VSS is the same, but I don't know if it will have the same final drive ratio. You might also want to use the torque converter from your 1996 regal. I know a lot of people say they are all the same, but I could tell a difference when I replaced my 3100 torque converter with a Ciera one.
