i tryed to do the acumilator shim project this morning and the whole washere thing just really dident work to my likyings so i was wondering if any one has a set of stiffer scumilator springs
stiffer acumilator springs
1994 Cutlass Supreme Convertible 3.4 DOHC
1969 Oldsmobile 442
1997 Chevy Tahoe
http://members.cardomain.com/mperkins442Tags: None
the 2 inch washere dident fit into the boors.......i would have had to grind some of the washer material off to make it fit... if im going to to have to do something like that i would just rather do it right and put stiffer springs in it.....pluse when i got down to actually doing it ... i just dident really like the idea of the washers1994 Cutlass Supreme Convertible 3.4 DOHC
1969 Oldsmobile 442
1997 Chevy Tahoe
you need to get what are called "Machine" washers, I found several direct fits in different thicknesses. You'd still be better off with stiffer springs.Brian
3400 SFI V6, 4T60e
which is the rought that i would prefer to go any way1994 Cutlass Supreme Convertible 3.4 DOHC
1969 Oldsmobile 442
1997 Chevy Tahoe
