I have a 92 Z auto and my lockup isn't kicking in at all. The harness is plugged in and tight. The fluid is clean and shifts good. No SES light. It does shift a bit fast but I can adjust the detent to correct that. My question is what would be some possible INEXPENSIVE ways that would cause this problem. I went to a trans shop today and the guy was talking about valve body problems, fluid pressure issues, bad internal seals, he also said the solenoid likely isn't the culprit. What do you guys think. Let me know.
Brian
Brian
