95 Cutlass - Overdrive Issues
  • 95 Cutlass - Overdrive Issues
    Does anyone know what would be causing my 4t60E trans to lose Overdrive after about 25-30 minutes of driving? I can get it to work again by turning the car off & on. It will work for a while before doing the same thing again. Any ideas?
    Mine wasn't working at all so the brown wire going to the trans is no longer connected. Lockup works but is not longer smoothed on engage. I couldn't tell you what is wrong but you could try this out and see if it works for you. Or maybe someone has a real fix for you.
      this could be an electrical issue. the best thing to do would be to get a scan tool with a data stream onto the car and go for a drive till it acts up, when it does, look to see if the pcm is commanding overdrive. if its not, you have a sensor input problem (tps, map, vss, ect).
