My mod. says holley on it. Is this aftermarket?
Adjustable Modulator 4T60E
Sounds like it.SpudFiles
Theopia
Enjoy life online.
Really? Mine is large, gray, and totally blank.SpudFiles
Theopia
Enjoy life online.
I thought mine was the FPR.
I just ordered mine...I couldn't resistLast edited by Z3R0; 08-16-2007, 12:55 PM.Originally posted by wozxx...{is 92 mph in a school zone illegal?}I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
There is a 10mm bolt holding a very simple bracket that holds it in, just remove that and the modulator pulls out. Then insert new one. My new one had a few different things you could take out of the end, and the instructions showed changing them out for different trannys, but on ours you just put it in like it came (take off the rubber protector!).
Put it on, then put the bracket back on and bolt it down. Then take the 90* bend that comes with it, stick it on, then look at what rubber fittings you have on the stock hard line. There are 3 if you pull the whole thing apart, you only need 2, you should be able to figure it out.
Connect it to the 90* bend, and you have a new modulator installed. As far as pressure, mine was 10 "turns" of my wrist open (Meaning it took 10 turns to close fully), so I closed it then opened it by 5 turns. I don't know if this is too much/enough yet, but it does go into drive/reverse much firmer.
Doing this is only extending the life of your transmission. As long as your not maxing the tranny pump all of the time (wearing it out), you'll be fine. More pressure = less clutch wear = more performance = longer life. Only reason it isn't like that stock is because most people don't want to feel their car shift.SpudFiles
Theopia
Enjoy life online.
Last edited by Z3R0; 08-20-2007, 11:41 AM.Originally posted by wozxx...{is 92 mph in a school zone illegal?}I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
Thats the one I have. Comes with most Full rebuild kits.
where is the adjustable part on this thingOriginally posted by wozxx...{is 92 mph in a school zone illegal?}I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
right down the middle of the vac hole, its a small flathead screw in there that goes in and out.
Well crap this is so cheap I might as well do it. There isn't any risk of leaks or anything by pulling this out right and slapping the new in?sigpicNew 2010 project (click image)
Dammit It Started Pouring Like The World Was Ending While I Was Under The Hood!!!!!!!!!!!!!!!!!! /pissed
I hope nothing essential got soaked
Oh yeah...pics please?Last edited by Z3R0; 08-20-2007, 05:33 PM.Originally posted by wozxx...{is 92 mph in a school zone illegal?}I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
Its lefty loose and righty tight right....Originally posted by wozxx...{is 92 mph in a school zone illegal?}I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
