95 4t60e to 96 4t60e, reluctor ring change, easy?
  • 95 4t60e to 96 4t60e, reluctor ring change, easy?
    Hello all!
    I just bought a 95 Olds Ciera with the 3.1 and 4t60e trans, and of course the trans is junk...My friend owns a towing business and has a good similiar trans from a 1996 gm product out back that he said i can have. I researched both transmission and found out that his trans is from a 96 olds ciera 3.1 also, has the same drive ratio and all, but has a different tooth count reluctor ring than mine, 31 vs. 30. Are they hard to change or should i just buy the correct transmission for my car? My trans is a 615PAW and his is a 616PAW model. Any help would be GREATLY appreciated for life!..
    Thanks
    Paul
    It should be a relatively easy change since the nose of the 60E can be separated from the case. And then the wheel should be right in that area.
      if your diff from your tranny is in good shape, id just swap the whole diff over.
