how to shim a 4t60(e) accumulator
  • how to shim a 4t60(e) accumulator
    how did you do thisi plan to doit but i have no idea what i have to do and what to change the springs to or what type of shims to use plese give me a breaf walk through
    thanks eurolumina92
    They gave you the link to it on W-body. Check out the link, that tells how to do it
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
      do i want to put the shims at the tpo by the piston or at the bottum and would it be better to use softer or harder springs
        You use the same springs, thats the whole idea of the shims. The shims are 2" OD washers, I would start with 2-3 in each accumulator then go from there. When you take the accumulator apart, they go down inside the hole.
          I used, and recommend a .5" stack of washers in each cylinder. I would actually add one more washer to the 1-2 also. And yes, put the washers on the BOTTOM of the assembly (not where the cap goes on).
            so it will go cover piston spring washers right in that order
              No. There isn't a "piston" per-say. From the bottom up, there will be: washers, springs, center pin/rod, and cover. I believe there are pictures of this on Brian's website. www.brian89gp.com
                Very last picture.
                  so that takes care of the 1-2 shift and the 3-4 shift what about the 2-3
                  1994 Cutlass Supreme Convertible 3.4 DOHC
                  1969 Oldsmobile 442
                  1997 Chevy Tahoe
                  http://members.cardomain.com/mperkins442
                    1-2 and 2-3 are together, they are in the same housing. 3-4 you have to take the tranny halfway apart to get to.
                      oh ok
                      1969 Oldsmobile 442
                      1997 Chevy Tahoe
                        thanks every one for the input
