Hi
I have been lurking for a while, but now I finally need to ask for some advice. I have an underpowered 85 Toyota Dolphin motorhome (6000lb with the 22REC engine) and sitting below my workbench is a perfectly good 3400 V6 from a 2004 Montana with low miles.
I would like to combine the V6 with a 4L60 transmission (I believe a version of the transmission was made for the S10 pickup with the correct bellhousing for the V6). Assuming that I can locate the right bits, I then need to find a way to get the engine to run. This is where I have the most headaches. What is the best method to get this engine to run in a non target vehicle ? The 2004 ECU / BCU disabled both fuelling and ignition and would be a big deal to install in a foreign vehicle. The controllers themselves are not that expensive, but a custom loom would be required together with an ignition key/switch/lock that matched the codes in the ECU and BCU. I have tried to do this with an ECOTEC engine from a Cavalier, but have not been able to get around the theft protection system.
Considering that my motorhome is only worth $5k at present, theft protection is not at the top of my list of priorities.
Are there any ready made solutions for this situation ? How do hot rodders get modern engines into their machines or is it simply not happening ? I know I could get an aftermarket ECU and tune it on a rolling road dyno, but that is a lot of work.
Thanks
Keith Olivier
Thanks
Keith Olivier
