The TCC in my '92 Lumina will occasionally disengage at a constant cruise speed, such as 60mph on flat terrain. It disengaes and then will re-apply after 15 seconds or so. It doesn't do this very often. It will do this once in about 15-20 miles or so.
It started doing this a few days ago. I serviced the filter and fluid yesterday but this didn't help. The fluid isn't burnt and the transmission shifts fine.
I'm thinking it's more of an electrical problem than a hydraulic one. Perhaps I'm losing the TPS or VSS signal momentarily, or the brake switch is faulty.
My next attempt at a diagnosis is to connect my scan tool to see if I can get a VSS or TPS reading when the clutch disengages.
Any other thoughts or comments would be welcomed. BTW, the transmission is original to the car and has ~134k miles on it. It's never given me any problems in the past.
TIA
TIA
