For all those familiar with a 284, I'm having a little problem with mine. When it sits for any time, say over night, the clutch system looses all hydraulics. After pumping it about 30 - 40 times, it will work again and is drivable.
Sounds like a small leak to me, I have looked over everything real good, and the only part with any fluid on it is the (i dont know what these parts are called) part right before the actuator that bolts to the transmission. The manual calls it the "canister". Is this thing the slave cylinder? I can't find where its leaking at, but it has fluid all over it (not a whole lot, but it has eaten the paint off), and down the hydraulic tube to the actuator.
Any comments or help is greatly appreciated. Thanks!
