There is a 4T60E on a corsica at the junk yard. is it the exact same as my 4t60e on my beretta? i know that in my corsica that had a 3spd the gears were longer than my 3spd beretta. so are the gears longer in the corsica with a 4t60e? im not puttin in a trani with longer gears. also i found alot of 4t60e's that inside the car is a collumn shift and it reads all four gears, and the beretta is on the floor and reads Low, drive, and overdrive, so how would this work? Is it the same trani or not?
Are all 4T60E's the same?
1996 Beretta
3100 SFI TURBO
13.1 @ 103 mph best in the 1/4 mileTags: None
They are all the same minus the FDR. That would make it longer/shorter through the gears.
Im not sure if a 94-95 is the same as a 96 though. I need to know that for my 96 GTP as I have 2 transmissions here now. If you use a 3.1 W body and a 3.4 W body transmission, you can make a 3.73 fdr. That would be shorter than your stocker
Originally posted by SappySE107 View PostThey are all the same minus the FDR. That would make it longer/shorter through the gears.
Could you tell me what I would need to do this? Would love to shorten the gears a bit in my GT,(2000 GA GT1) but didn't know it was possible! Thought I had to do a GTP conversion or something.
Paul
There are actually several different models of 4T60E in just the same year, so you really have to match tranny codes to get an "exact" match. Differences include what sensors are used and could alter the internal wiring some.-Brad-
What trani codes are you talking about?
1996 Beretta
3100 SFI TURBO
There is a tag on the tranny house with a 4 digit code.
The ones with a 6 for the first digit are 96 model year IIRC (15 different models).-Brad-
Originally posted by MMGT1 View PostCould you tell me what I would need to do this? Would love to shorten the gears a bit in my GT,(2000 GA GT1) but didn't know it was possible! Thought I had to do a GTP conversion or something.
Paul
a 2001 gagt will have a 4t45e, not a 4t60e. im not sure, but a 4 cyl 4t40e may use different gearing than the v6, so there may be parts avalible to do a gear swap.
that helps some. so the corsica trani would have a different final drive ratio? What about tranis with different codes. is it possible to find a better one? if so what is the best trani to put in my 96 beretta 3100.
1996 Beretta
3100 SFI TURBO
do 96 4t60e's in berettas suck? because mine went and so did the one at the junk yard, but my freind has a 95 beretta 4t60e and we do burnies in it all the time and it is fine, now wtf?
1996 Beretta
3100 SFI TURBO
my trani is a 6WFW, good, bad? will any other tranis work.
1996 Beretta
3100 SFI TURBO
Yea, my trans is a 4T45E. 2000 Grand AM GT(329 final drive, factory)Originally posted by sharkey View Posta 2001 gagt will have a 4t45e, not a 4t60e. im not sure, but a 4 cyl 4t40e may use different gearing than the v6, so there may be parts avalible to do a gear swap.
So, there is nothing that can be done with this one?
my fdr is 3.29, would a 3.33 fdr make it faster?
1996 Beretta
3100 SFI TURBO
