trans knock after warmed up ?
  • trans knock after warmed up ?
    started my car today after i adjusted the rad fluid, cuase its going down below -30 here
    so anyways i noticed it started knocking after a good 15 minutes of idling
    so i grabbed my new camera i got for x-mas
    and took a video becuase thats the only thing handy that records sound :P
    sorry, kinda big file
    its a rebuilt 4T60E btw
    Hightail Spaces lets you send unlimited files, of any size, to anyone. Collaborate with your team and evolve your work.
    ..... i gotta get rid of that rev limit :P
    gotta be logged in to d/l it.
    typicaly transmissions dont knock, and if it had a noise in the geartrain that may cause a sort of noise like this, it wouldnt matter hot or cold.
      Might be the 2-1 band recoiling around the reverse reaction sun drum assembly. If the band was bent enough during assembly, it'll for a split second engauge drive. You won't feel it, just hear it and only when you rev it up in neutral. Should only happen when its cold.
      Lorenzo
        i know its frickin odd
        i wonder if it could be a rod bearing on that side 5 or 6 ?
        but only knocking when warm and goes away with the rev, bu returns when the revs come down
        the oil thins out and it then starts to knock ?
        god the motor was rebuilt not long ago
        guess if its a rod.... simple bearing change if the cranks ok?
        or its time to put a 3.1 crank and rods in lol ugg
        are there any sites that i can host the video, that are good where one doesnt need to register to download?
          Email and I can host on my FTP?
          Or I will give you a username and pass to upload it.
          Can't have just anyone uploading, I might run out of space, 300Gb isn't that big anymore.
