Hello all. just found this board .
I had to put in a used 4t60e trans out of junkyard ,100,650mi. on it , the guy said it worked, prob. is it does work but only in 2nd and 3rd gear , now my old trans did this same thing so I put a tcc sol. in it , but finally puked for good
I took pan off and it is very clean , not burnt or brown fliud. I have checked all conn. and things look good. any thoughts . my ERLS fuse is not blown,which is how I knew the other was bad,(reason I bought tcc), I kept the tcc out of previous trans,
You think this one could be bad or what do ya'll think could be problem
this is a 94 Grand Am , trans out of a 95 GA
TIA
Scott
TIA
Scott
